SL-Class (R129) 1990-2002: SL 280, SL 300, SL 320, SL 500, SL 600, SL 60 AMG
SL/R129: Help! Hard top stuck in A pillerlock before I located the rear locating pins!
Old Nov 27, 2009 | 08:37 PM
seattlekleeman's Avatar
Birel Shifter,2003 Ferrari ,1992 Mercedes 500E,Superformance Cobra,2005 SL55, 2004 996tt X50 PCCB
I have not had my hard top on in years and while carefully lowering it onto the car today made the mistake of locating the front (windscreen latches) first (instead of rear first). They grabbed and now the front latches are engaged and the rears are out of position. The fronts now will not release! I think that I have tried everything but am stumped!! The rear locating pins on the hard top are now about an inch behind thier respective locating "holes" and putting pressure on the bodywork (now protected by some towles).
Any ideas would be truly appreciated !!!!
Old Nov 29, 2009 | 11:21 PM
SL320Merc's Avatar
Mercedes SL320
Help with stuck hard top
There's a tool in the tool-kit especially for if this happens. One side is a spanner head and the other is an Allen key that FITS behind the caps behind the sun visors on both sides to RELEASE the latches... ping - one side... ping - the other side - top off!
Old Dec 1, 2009 | 03:50 PM
SL320,
THANK YOU!
Your tip worked like a charm!
This forum holds an incredible brain trust!
Old Apr 28, 2013 | 11:33 PM
Boxman20c4's Avatar
1997 Mercedes SL320
Thank you ! I was about to panic !
Steven
