SL/R129: Euro Spec headlight fitment question...
Sorry my first post is a question without an introduction, but I'm in a bit of a pinch.
I purchased some new bezels yesterday but I'm going to return them and go with new Euro Spec headlights instead. I have to replace one lens, so that means two news lens so they will match. That's $300 vs $535 (@ Adsit) less $50 rebate for one "good" old unit. And I'm not certain my 20 year old plastic tabs on the housing won't break off.
I've searched read every post I can find on all sites and would like to claify a couple of things from those who have done this mod...I undertstand these are suitable for left hand drive, correct? Am I correct they are not exactly plug and play - the old plug has to be re-used correct? Is this difficult? Other than possibly a plug, the euro's don't use any of the old housing, correct? Even the rubber fitting around the old housing? And Adsit tells me the wipers will no longer work - is this correct?
Thanks in adavance, ep
Thanks, ep
The "before" pics are taken as the car came off the transport from SoCal. My wife's uncle didn't need it anymore, so I went about a "rescue". New PS Pump, antenna motor and mast, battery, new OEM pads and rotors all around, new Michelin Pilot AS's, changed all remaining fluids (Oil, coolant, differential and transmission service), then repainted the front bumper and installed new fog lens and the Euro headlights.
Next up - OEM shocks and an alignment (asap), new hood pad (sometime in the next month) and new leather seats and padding (spring).
The car has 270 on the clock but it had a new engine and wiring harness at 205k along with very regular transmission services.
ep (Frisco, TX)
Last edited by epfrisco; Jan 2, 2010 at 10:10 PM. Reason: adding pics and description of work done
Rick
ep
