SL/R129: passenger window won't budge on 1990 r129
R129, W124
For the last couple years I've had to be careful to not put the passenger side window up all the way to the very top. Otherwise the window wouldn't go down again without 'helping' it by applying pressure to the top of the glass, usually near the rear of the door.
Well when I put it away for storage last fall I must have had the window too far up, and now I can't get it to move even with pressure.
Just to be sure I swapped the fuses around with the drivers side and that's not the problem. I also checked the limit switch in the bottom of the door and it doesn't seem to be sticking.
Can anyone help? Thanks for any insight.
