SL/R129: Repair Hydraulic cylinder Soft Top
![Smile](https://mbworld.org/forums/images/icons/icon7.gif)
Hi Gang,
I understand the Hydraulic Cylinders to operate the soft tops detriorated and eventually leaks more base on duration than on frequence usage. By now most of the cylinders on my 91 SL 500 is either leaking or about to. I have checked with the Merc agent here in Malaysia and the parts are pretty expensive ranching from $350 for each cylinder. I understand that there are several. How many cylinders are there in a 129 Does anyone knows???? Question is does anyone know of anybody refurbishing or repairing these cylinders...??
Cheers- Heung
Cheers- Heung
'87 560SL Sold, '99 SL500 For Keeps
There are closer to a dozen cylinders involved in the complete operation of your soft top; from moving the top itself, opening/closing the storage cover, roll bar, etc.
PM me with your email address and I'll send you a schematic of all of them, location, type, etc. The file is to large to upload here. You are absolutely correct that the seal deterioration is from heat and age moreso than use.
Bob
Bob
jeddyt (05-21-2024)
95 SL 500, 08 Infinity FX35
I had both front cylinders repaired by Dennis 2 yrs ago for about 30 bucks each. Not sure if he's still in the repair business. Here's his contact info
Mercedes Hydraulic Cylinder Rebuilder
Dennis Ficken
16285 S. Chester
Olathe, Ks 66062
(913) 390-0506
mercedescylinders@sbcglobal.net
Dennis Ficken
16285 S. Chester
Olathe, Ks 66062
(913) 390-0506
Thanks Guys for the informative replies. Bob pls sent the info to my Email address. heung_kk@yahoo.com
Thanks- Heung
Thanks- Heung
Sending now...
Whitelist my address... bjonesny@aol.com , so the yahoo server will accept the large attached file.
Can I get a copy of that schematic?
Bob
Bob
the cylinders for the soft top of my 94 SL 500 cratered today and i wanted to ask if you would send me the schematic referenced in this thread. thanks jbs@sargentconsulting.net
2012 SLS AMG Roadster
Try tophydraulicsinc.com. They will rebuild all of them ( 11 or 12 depending on model yr) for $550 plus they have instructions on their website for removing them.
Baybear
Baybear
I agree, top hydraulics is the place to go. Just had mine done and couldn't ask for a fairer or better person to work with than Klauss.
'07 E63; 05 C55 gone; '02 C32 gone;1996 SL320;1978 280CE Gone
Dennis Ficken did mine a few months ago. He said he gets these parts in from around the world. Contact him for details.
SPONSOR
![Thumbs up](https://mbworld.org/forums/images/icons/icon14.gif)
It is important to note that we use far better seal material (chemically stable) than OEM. Mercedes has slightly improved their seal material in the late 90s (when introducing CLK and SLK), but those are now failing on a grand scale, as well. We find the SLK seals to be a close match in seal material to what Dennis is using on those rebuilds of his that we are rebuilding...
One can argue that very infrequent use is more harmful than frequent use, because the cylinder shafts get lubricated less. However, that is a minor effect. The single most important thing you can do to extend the life of your cylinders, is to flush your hydraulic fluid every 3-5 years. Use MB approved fluid, which is available as the fluid from the dealer or online as FeBi 02615 (just put 02615 in your favorite online place's search box).
2 Front Lock Cylinders: http://tophydraulicsinc.com/R129%20F...%20Removal.pdf
2 Rear (Bow Window) Latch Cylinders: http://tophydraulicsinc.com/R129%20R...%20Removal.pdf
2 Tonneau (Case) Cover Lift Cylinders: http://tophydraulicsinc.com/R129%20T...0Cylinders.pdf
1 or 2 Case (Tonneau) Cover Lock Cylinder(s): http://tophydraulicsinc.com/R129%20T...0Cylinders.pdf
2 Bow Extension (Window Flip) Cylinders: http://tophydraulicsinc.com/R129%20B...%20Removal.pdf
2 Main Lift Cylinders: http://tophydraulicsinc.com/R129%20M...%20Removal.pdf
Those who are contemplating DIY, do the math first, please:
It costs over $6,000 to get all cylinders new from the dealer. That makes for an average cost of over $500 per cylinder. What do you think your chances are for accidentally nicking even one out of 12 cylinders? (Let me tell you, they are huge for most people...) We have the right tools at Top Hydraulics, custom made for each cylinder. It can be rewarding to do the seal replacement yourself, but devestating when you realize it cost you many times what the pros with the warranty would have charged. And what will you do when you find that you have to replace the piston seals as well? Those are highly customized.
-Klaus
klaus@tophydraulicsinc.com
(The schematic below shows up as a thumbnail. Click on it, and you will get higher resolution. Go to our website's FAQ section for a crisp image.)
![](https://mbworld.org/forums/attachments/sl-class-r129/219608d1317695773t-location-all-your-soft-top-hard-top-hydraulic-cylinders-removal-instructions-r129diagram.jpg)
Soft Top hydraulic repairs
Does anyone know of a service near Richmond Va. that can install the hydraulic cylinders for the soft top activation( not the dealer). I plan to get Top Hydraulics to refurbish them, but I am not a DIY, especially not with cars
