SL/R129: good ol!!..asr deploying ITSELF!!
r129 500sl 1990 & w124 300 ce 1989
![Question](https://mbworld.org/forums/images/icons/icon5.gif)
![Confused](https://mbworld.org/forums/images/smilies/confused.gif)
I HAVE JUST FITTED MY NEW BURLWOOD INSTRUMENT CLUSTER FACE BEZEL!!
WOOOW WOOPEE!!.....LOOKS GREAT!.. THOUGH NOW MY [ASR-LIGHT COMES ON TEN MINS INTO DRIVING].....I GET HALF OF MY ACCELERATION & WHEN I TURN OFF THE ENGINE & RESTART ENGINE ALL IS NORMAL FOR AWHILE & THEN ASR TURNS BACK ON!!...THIS IS DOIN MY HEAD IN!!..WILL I EVER GET TOO ENJOY A UNTROUBLED DRIVE WITH THIS CAR!.......EVERYTIME I FIX A PROBLEM I GET A NEW PROBLEM & ALWAYS WITH CLUSTER WARNINGS!!.........ANYONE HAVE INFO FOR NORMALIZE-ATION OF MY [ASR]..I WANT IT OFF LIKE IT USED TOO BE!!!!
![smash](https://mbworld.org/forums/images/smilies/smashfreak.gif)
![bow](https://mbworld.org/forums/images/smilies/bowdown.gif)
Ifinally had this issue resolved, just a few days ago I started the car up since the car was sitting for a few weeks, the battery died so I had it replaced. Once i replaced it, the issue resolved itself so I believe the battery was the culprit, probably not charging or have sufficient current to run the car....
![drive](https://mbworld.org/forums/images/smilies/driving.gif)
I ALSO FOUND THIS REPLY!... TO SOMEONE,S ASR ISSUE!
IF MY BATTERY CHECKS-OUT THEN I WILL LOOK INTO THIS SUGGESTION!
If you want my advice just replace trans neutral switch, I had the same problem with one of my customers car and the problem solved. BTW did you inspect the harness?
& LABOUR?........HARNESS SEEMS GOOD
THE NEW BATTERY HAD NO EFFECT!!........[VERY DEPESSED
trans neutral switch was quoted for me as $160-then when i spoke too a mb tech he could,nt understand why the switch would be connected with "asr"......i am just getting more confused! ;-[[[[[
