SL/R129: hardtop for 95 SL320
Allan Saunders
I am at tracker123@att.net
So yes I believe you can properly install the hardtop. The system will tell you if the process did not complete, in case you run into difficulties, the red light that activates the hardtop mechanism will flash if the entire process did not complete. The car will also create a beeping sound if you are driving the car the mechanism not properly closed, or opened.
Hope this helps,
JR
Thank you for the investigation and the reply. I am a new owner and not many folks to ask here. Finally found a top only a 5 hr drive away. I am East coast transplant living in East Tx and hardtop is in Baton Rouge. Will pick up in a couple of weeks.
Allan Saunders
