SL/R129: Soft top not latching
sounds like your cylinders are not making it past the dead spot.
Four questions: One, have you tried to push the top down into the locks by hand? If that helps, then you must have too little pressure in your system.
Two, how is your hydraulic fluid level in the pump? If the pump is sucking air, you won't get enough pressure to latch.
Three, have you cycled the system a few times? That should get some air out.
Four, have you checked the other cylinders for leaks? Working on the system may have caused another seal to blow.
I just had all my cylinders remanufactured by Top Hydraulics, and couldn't be happier. They post R&R instructions on their website, turned my cylinders around in a day, and gave me a three year warranty. www.tophydraulicsinc.com, ask for Klaus.
