SL/R129: Front wheel problem ?
Now that it is warm it doesn't do it ... but it does feel like the alignment is off for the 1st few minutes until the car warms up. I confirmed that the wheel is properly bolted on and I jacked the car up but didn't see anything obvious.
The wheel has never hit anything - I've driven every one of the 22k miles carefully. However it had a couple of scratches on the passanger side front wheel (AMG) when I picked it up new from the dealer so I suspect that it may have taken a knock before I got it. When I took delivery the salesguy told me that it had a vibration which they fixed by replacing the rubber.
I will have the dealer look at it when I bring it in for service but I would like to give him a little more to go on than "it comes and goes depending on the temps."
Ideas ? Suggestions ?
However, if the bearing is bad it must be replaced. You should have this checked asap, as it could heat up and seize causing greater problems.
THAT SOUNDS LIKE A NICE TECHNICAL EXPLANATION BUT ITS WRONG!
