SL-Class (R129) 1990-2002: SL 280, SL 300, SL 320, SL 500, SL 600, SL 60 AMG
SL/R129: central locking not working 320sl
Old May 20, 2011 | 06:37 AM
tiern8546's Avatar
mercedes 320sl
hi,can anyone help, the central locking will not operate from fob, however i am able to lock manually with key when i press the button the green and red light work as they should allowing me to start and run the car it's just the locking doesn't work,have noticed also the door pockets,small glove box and arm rest which lock from the key will not open either,is there a fuse for this regards mike
Old May 24, 2011 | 12:21 PM
mdm6713@aol.com's Avatar
1997 SL320 Sport
not an expert but first thing I would check is if an air hose fell off, do any of the other locks work? trunk..etc...
do all locks turn with the key
Old May 24, 2011 | 01:04 PM
tiern8546's Avatar
mercedes 320sl
no locking from fob
hi,the trunk locks and opens with key, passenger door locks from internal (keyless).immobilser all working as it should i.e. red and green light on drivers door and rear view mirror flashing unable to open armrest , pockets on door cards and arm rest/centre consel any advice would be greatfully appreciated
regards mike
Old May 27, 2011 | 06:43 AM
tiern8546's Avatar
mercedes 320sl
internal locking not opening
hi,does anyone know if there is a fuse for the internal locking system all the locks are shut nothing happens when i turn the key in the switch next to the specatcle compartment regards mike
