SL/R129: healight washer pump running
Location: Alabama gulf coast, formerly Charlottesville, Virginia
2004 W220 (S430), 2001 R129 (SL500 Sport)
When I turn on the headlights of my 2001 R129 SL500, the headlight washer pump runs the washer fluid reservoir dry. With the headlights off, the pump doesn't run. I am expecting it may be in the steering column switch, but hope it is a fuse. I can't seem to find a fuse diagram for the car. So I need (1.) diagnosis of the likely cause for my problem, and (2.) a place where I can find a fuse diagram, so I can see if there is a fuse issue.
If there is a separate fuse for the headlight washers, I'll just pull that sucker out and solve the problem that way.
Thanks in advance for the help.
Dr. J
Dr. J
