SL/R129: Loud droning noise w/ hardtop on between 50-60 mph
Cheers,
Jeff
Cracking the windows and/or playing with the air circulation didn't have an effect. I also tried putting it in neutral to see if that stopped the sound, but it didn't, nor does weaving back and forth change the the tone/volume at all. There's no shimmying or unusual tire wear and the alignment on all four tires checks out fine. When changing speed, the sound only starts up at about 50mph, peaks at around 53mph and tapers off in volume by 57mph.
Nevertheless, try driving when the drone is the loudest and turn the AC unit to 'Recirc'. Make sure you can hear the baffles changing position. That action should cease to allow air to rush into the cabin from over the cowl.
Assuming that doesn't have an effect, do you feel *any* sort of minor vibration in the steering wheel, especially at the infamous 53 MPH point? Wondering if maybe a front wheel bearing is getting worn. Or perhaps a rear wheel bearing, though when one of those starts to go you sense it more in a particular turn direction.
If it's not engine speed related or cabin pressure, there are only a couple moving parts relative to street speed - wheel bearings, rear axle gears, driveline. Though maybe you have something loose underneath the vehicle and it vibrates at a particular frequency, at a particular speed. Check the 'belly pan' under the engine; it's held in pace with 4 screws that become stripped over time. Short of actually hearing the noise, it's tough to second guess the issue.
Cheers,
Jeff
To check for this, cover all these trim pieces with masking tape and go for a drive. If the noise goes away or significantly changes, you have found your source. Start peeling off tape until it comes back, and now you have your loose trim piece.
If the noise is more felt than heard, check or have someone check the flex disks on the drive shaft. Worn flex disks can cause vibrations in the 40 - 60 MPH range. Common problem on the R129 and W124.
Hope this helps (I hate "noises" too).
- FD
