SL/R129: Drop Top rear windows.
97 500sl. Thanks
http://www.r129motoring.com/R129M_St...uct=3&category=
This is a complete "Do It Yourself", Plastic Rear Convertible Soft Window Replacement Kit for any Mercedes-Benz R129 or R107 SL Roadster of years 1971 to 2002. Included within this kit is everything you need to replace your windows. The proper specialized tools, supplies, windows, and the very simple to follow Step-by-Step instructions (Written in English), with pictures and videos of the proceedure. From start to finish you can do it yourself in just a few hours.This easy to install window kit is all you need to replace your cracked, scratched or browned plastic windows in your soft top. The R107 Kit: 1) DOES NOT have a video to watch (2) Will only work on OEM tops, or tops that have been made to OEM Specifications. When in doubt, ask! (3) Lastly the window Trim & Seal only comes in black at this time.
- No Glues or Solvents are needed
- You don’t have to be a professional seamstress.
- You don't need any experience.
- You don't need heavy equipment.
- You don't have to remove the canvas top.
- One Person can do it alone.
These are not OEM Plastic windows. Technology has advanced tremendously since the 1990’s. This kit contains the latest high technology thread and plastic windows that are harder to scratch, more resistant to the effects of UV rays, and are rated to perform under normal conditions for up to 5 years.
You choose between 3 Colors:
- Clear
- Euro Green Tinted
- Tinted factory 30%
This kit will work on any 1971 to 2002 Mercedes Benz SL models R107 & R129.
I am very happy with the result, but want to make sure you know what you are getting into
