SL-Class (R129) 1990-2002: SL 280, SL 300, SL 320, SL 500, SL 600, SL 60 AMG
SL/R129: 1996 Center Vent Clips
Old Dec 4, 2011 | 07:52 AM
Black96's Avatar
1996 SL500 Black on Black
I removed the center vent to replace it. The vent is held by 4 screws. 2 are under a small plastic piece, 2 are in the box. The two screws under the plastic piece go through the vent and into a "clip" or insert that fits into a slot in the dash. Does any know what the "clip" is really called and how can I get a part # for these. The old ones are cracked and I think the vent will rattle if I try to reuse them. I tried the dealer but they had no idea what I was talking about and their computer doesn't show it. Thank You
Paul
Old Jan 12, 2012 | 05:35 PM
SRHsl600's Avatar
94 SL 600, 98 993, 89 XJS Conv., 85 Daimlier Princess 16 Hybrid Lincoln 16 Chevy crewcab
I do not know of the vent clip.
Often sheet metal screws in one side approach areas use a folded over metal clip that covers a wide hole where a wide flange screw can auger into the "clip". The item is called a speed nut or screw bolt. Auto parts stores and hardware stores ( in the sliding box display, usually with the bolts, nuts et al section ) have them in many sizes ( both to clip over the hole, as well as match the thread spread of the bolt or screw ) and metal qualities. most often I buy a stainless clip but the black matte finish is a must in a vent, hidden screw application. Hope you can find the right product
Old Jan 13, 2012 | 12:27 AM
Black96's Avatar
Thank-you for your reply,
I found out that those large holes should have a plastic center piece that has a small hole in the center for the screw that holds the vent. I used epoxy putty to fill the large hole, then drill a small hole in the center for the vent screw. It seems to be working fine.
