SL-Class (R129) 1990-2002: SL 280, SL 300, SL 320, SL 500, SL 600, SL 60 AMG
SL/R129: Battery light - ON and OFF
Old Mar 4, 2012 | 01:50 PM
BENTwrench's Avatar
SL600
I have a 1994 SL600 with an odd battery light issue.
Last night my battery light came on. I drove the car for a couple minutes and the battery light went off. After a few more miles the light returned.
Today, I started the car and the battery light was off. After driving for a few hours, the battery light returned. After pressing hard on the accelerator, the light would go off. When I stopped accelerating hard, the light would return. This is not a 100% correlation as there were times the light did not go off and I was at wide open throttle.
I just started the car about an hour ago and the light is off.
Any ideas? I made sure the battery and the wires connected to the positive terminal are connected tight.
MUCH APPRECIATED.
Old Mar 4, 2012 | 04:19 PM
silverarrow007's Avatar
2002 SL 500 Silver Arrow
sounds like your alternator maybe or possible loose connection to battery
Old Mar 4, 2012 | 04:22 PM
you say possitive tight also ground clean & tight ?
Old Mar 4, 2012 | 04:23 PM
Battery on its way?
Old Mar 5, 2012 | 12:20 PM
BJonesFL's Avatar
'87 560SL Sold, '99 SL500 For Keeps
If it were my car, I'd start with a battery test under load; then look toward measuring alternator output. What you're describing though reads like the voltage regulator as probable cause.
Bob
