SL/R129: Need - Outside Mirror Disassembly Procedure
Cheers,
Jeff
The trick is reassembly because if you align the glass wrong, you can break the attachment points. So be careful! You have to line up the glass so it pops onto two motor arms, which terminate in small *****, AND the center swivel.
Just don't force anything (speaking from experience). It's easy to break the ball off the end of the motor arm. So, look it over carefully, take your time, and line up the three "snaps" with care.
