SL/R129: codes wont stay cleared
I have had some systems "code". The particle size in the air sensor is microns that set my CEL off! Fluid levels in the suspension hydraulics and all fluid levels have set off codes that were very easy to DIY.
Our generation of 600's has both an old and new code systems and my indy uses two readers to clear the codes. ( I just watch I have not done! )
My "get home" method is ; disconnect the negative terminal of the battery in the trunk. I keep a battery terminal size box wrench in the tool kit near the CD changer. If I have the time I will keep the battery disconnected for hours.
When I restart the engine, I turn the steering wheel full right-left-back to reset the ADS ? and years ago, the sound system code.
Good luck with the new "love hate" relationship. It is kind of like family reunions.
