SL/R129: Dash Vents Air Flow
Mercedes Benz 500SL 1998
Dash Vents Air Flow
1998 SL500, r129: Have very little air coming out of the dash vents. Plenty out of the defrost and the floor.
The dash vents indicator light on the controls does not light up but the defrost and floor and combination of those two does.
Suggestions before I buy the control unit??
'87 560SL Sold, '99 SL500 For Keeps
The Climate Control Unit has both on-board real-time and stored operating values and error codes that will help you find the problem(s). The diagnostics can be run in less than 10 min by your service provider, dealer or independent. If you don't like that idea, pm me with your email address and I'll send the instructions to you. You may be able to find the same instructions on this forum using the 'advance search' option on the term 'climate control diagnostics'.
So check the thumb wheel operation first, then use the search tool for diagnostics instructions, last, contact me directly and I'll send them to you. Then we'll do your lights
Bob
