SL-Class (R129) 1990-2002: SL 280, SL 300, SL 320, SL 500, SL 600, SL 60 AMG
SL/R129: Mass Air Sensor
Old Sep 12, 2012 | 10:15 PM
afrts's Avatar
1995 SL320
Mass Air Sensor
I have a question...on a 1995 SL320 will the car start with a bad MAF..thanks for any help !!!
Old Sep 13, 2012 | 11:07 AM
SRHsl600's Avatar
94 SL 600, 98 993, 89 XJS Conv., 85 Daimlier Princess 16 Hybrid Lincoln 16 Chevy crewcab
my experience is yes for the start, however when the air sensor (s) is clean the CEL does not light up and the engine working range was wonderful.
I have purchased and had the shop install new sensors, ( counter to the mechanics advice) after the new harness (s) were installed because I thought the CEL would never come on! It has come on on a regular basis because of its sensitive nature, so that small particle Kansas air may be a non correctable factor. The car still runs great with no change in fuel mileage.
Old Sep 14, 2012 | 12:22 PM
afrts's Avatar
1995 SL320
When checking for voltage which wires do you check with a voltmeter on the harness connector to the air flow meter..? Thanks for any help !!
