SL/R129: SL 500 A/C wiring issues
1995 SL500 (R129)
Hi -
Does anyone have the part# for the wiring harness that connects the AC? Is it part of the lower wiring harness?
My A/C compressor cuts off an on at will - replaced all sensors, the 2 relays and the main control unit in the car.....
Also, I had to wire around the pressure cut off switch on the dryer to activate the auxillary fans - otherwise they would not operate at all - now they run all the time on high (better to keep the engine cool, then not)
Any ideas? I can oly think the wires are shorting somewhere - When the compressor runs, it runs fine with cold air.
