SL-Class (R129) 1990-2002: SL 280, SL 300, SL 320, SL 500, SL 600, SL 60 AMG
SL/R129: engine RPM
Old Jan 22, 2013 | 04:07 PM
carsfastfredi's Avatar
1999 500sl,1991 500sl,1964 T-bird convertible roadster,1964 t-bird convertible,1999 Harley roadking,
engine RPM
I have 1991 500SL..all of a sudden yesterday while engine was idleing inPark
the RPM went up to fast idle and now i have fast idle in park or nuetral. works fine while in gear? dont want to tear up my drive shaft. ANY help? THANKS GUYS.
Old Jan 29, 2013 | 02:13 PM
CIGAR_LOUNGE's Avatar
MERCEDES BENZ SE 300
if you added anything to it before that happened, then check that !!
M
Old Jan 29, 2013 | 03:32 PM
SRHsl600's Avatar
94 SL 600, 98 993, 89 XJS Conv., 85 Daimlier Princess 16 Hybrid Lincoln 16 Chevy crewcab
if from a cold start, then I think of augmented fuel mode. From your guestion mark I assume you have put the car in gear, is that correct? If you did add load to the engine, what happened to the RPM?
The engine RPM has a host of factors that E control unit monitors. Good luck!
