SL/R129: seat switch help please
The seat motors fore and aft movement and the up/ down movement work correctly, because when i press the memory button, the seat moves into position correctly.
once i have pressed the memory button the switch fucntions correctly for a few minutes, then it will only move the seat forward a little then stop, or back a little then stop!!!
i have tried a new switch and its exactly the same symptoms.
could somebody tell me what and where the position switch and relay are and what they do exactly.
i have removed the seat cushions to examine and all of the motors are working correctly...... any help is much appreciated.
Thanks in advance
Try moving the seat fully forward and up with the door open and without yourself or any one else sitting in the seat. It might just work. Hope all this helps.
