SL-Class (R129) 1990-2002: SL 280, SL 300, SL 320, SL 500, SL 600, SL 60 AMG
SL/R129: Wheel?
Old Jun 12, 2013 | 07:40 PM
aintnothang's Avatar
r129 190sl
Wheel?
I was looking at some amg aero 2 mono block wheels and wondering of they would be direct fitment on a r129. They are 17x7.5
Old Jun 15, 2013 | 07:43 AM
ohollenbeck's Avatar
04 E500, 00 SL500, 99 SL500, 94 E420, 92 500E, 92 500E, 92 300CE, 06 Lexus GX470
Most likely yes
All 4 wheels 7.5?? unusual... in 17" they came as a staggered set with 8.5 rears
You need to find out what the et is, it is cast into the back of the wheels..
will look like this "example" 7.5J x 17H2 ET35
Also on the back of the wheel is the part number, the first 3 digits are the chassis type.
The most common AMG Mono II 17" wheels are W202 wheels (C32, C36, C43).
The offsets on the C32 wheels are fronts =35 and rears =30, and will fit a 129.
If you do buy these wheels, they need 245/45's to make the overall diameter 25.7", which will keep your speedo and odometer correct.
This is the same size tire as installed on a stock 17 inch 129 wheel from the factory.
If these are C32 wheels, your buying 4 fronts. There are many sets of these around, and unless your getting them uber cheap, hold out of a normal staggered set, will look better on the car
A set of these pops up at least once a month or so on the common Mercedes forums.
If the et is different than 35, post back here what it is.
Attached Thumbnails Wheel?-c36-front-129-compare.jpg   Wheel?-17-amg-ii-stag.jpg
