SL/R129: Any suggestion how to fix this
1999 SL 500
Can anyone recommend how I can fix/camouflage this (see pic)
The only option I have now is to change the entire bumper but I don't have the $ for a major job like this
Love this car and would like to fix it for the summer.
Thank you
Thank you
94 SL 600, 98 993, 89 XJS Conv., 85 Daimlier Princess 16 Hybrid Lincoln 16 Chevy crewcab
I used T-nuts and threaded fasteners to hold the reinforced bonded layer on the inside. While I have used fiberglass on other R 129's the last materials more long lasting. the materials "sandwiched" were bumper plastic, two mix bonding compound, plate biocryl ( plastic that can be heat molded for bends and curves, that holds the acquired shape ) The T-nut was on the inside biting into the biocryl. The strength is wonderful after 4 years. Since my bumper is black the hide was easy. I used a rubber based black coating for the screw heads. They are not easy to see from the street.
