SL-Class (R129) 1990-2002: SL 280, SL 300, SL 320, SL 500, SL 600, SL 60 AMG
SL/R129: Temperature flow sensor
Old Oct 3, 2016 | 05:00 PM
betterdaays's Avatar
1999 SL500
Need to replace temperature flow sensor...$10 part but it's buried in it's own cubby hole. Some suggestions as to what all has to come off to get to it.
It's mounted right next to intake hose 1999 SL500
thanks
Old Oct 4, 2016 | 09:32 AM
SRHsl600's Avatar
94 SL 600, 98 993, 89 XJS Conv., 85 Daimlier Princess 16 Hybrid Lincoln 16 Chevy crewcab
IDK not sure about the sensor you refer.
the air intake sensor on older models is a rotation (30 degrees?? ) and lift out. Before the turn I disconnect the wiring. If memory serves there is a plastic squeeze lock in the wire connection.
