SL-Class (R129) 1990-2002: SL 280, SL 300, SL 320, SL 500, SL 600, SL 60 AMG
SL/R129: Right Tonneau Cover Hydraulic Line
Old Nov 25, 2016 | 05:52 PM
mkbch's Avatar
99 sl 500
Hey all,
I just have replaced all of my hydraulic pistons thanks to Klaus at Top Hydraulics. However, I have one issue, I can't make that tonneau cover lock to not leak fluid from when're the lines enter the piston.
Am I missing something important? There is a ridge on the steel line, shouldn't that go between the clip? Whenever I test the system, these lines are trying to back out of the piston. Should that ridge be all the way in the piston so that the bottom of the clip holds it in? I can't seem to make it go any further in as it is completely snug up to the brass piece.
