SL/R129: 1998 - Soft Top almost works...
I would pause the operation at the point it fails and manually move the bow well beyond the point at which it reverses and resume. I suppose it would reverse as before, and if it did I would again move it manually and then check the state of all of the inputs to the soft top controller with a multimeter. If you wish to do that and need help, reply back.
So, they say that when you are up to your a** in alligators, movement in any direction is defined as forward progress. I made forward progress today! 8^)
The hard top is on because this is the Seattle area, and you just can't live with the top off more than a day or two unless the soft top works. Today, out of the blue the top open/close switch on the console started blinking, and the chime started ringing to be annoying. At first pushing the switch forward would make it stop for awhile, but then it finally stopped helping.
When I got home from work I investigated the switches at the X2 connector on the soft top module. I measured them all with the top locked on, then took the top off (there was only me, so I held the top up with 2x4s off the car to simulate it being removed), then measured the switches again, then re-locked it down and measured them another time. The symptoms of the control switch being lit / flashing and the chime sounding disappeared when the top was locked back down.
The results were that all the switches were in the correct positions in all cases, except for X2 pin 28 (A22S2, Bow Locked) and X2 pin 46 (S84/3, Soft Top Open). A22S2 was initially open with the hard top locked on, was still open with the hard top off, but was closed (as it should be) when the hard top was once again locked down. It's brother on the other side of the car X2 pin 45 (A23S2) was closed, then open, then closed. Therefore, this A22S2 is barely adjusted right, or else the switch contacts are intermittent. I'm thinking it's the adjustment since I had a similar problem on the front right switch when I replaced the front hydraulic cylinders.
S84/3 is a different matter. It read 33.8 ohms the whole time. I would expect it to remain the same since the soft top wasn't moved, but a closed switch should read less than 0.1 ohm and an open switch should read well over a million ohms. There's no way the controller is seeing 0-1 volts through almost 34 ohms (I should think), so the controller is probably seeing an 'intermediate' state when it's time to close the rear bow, and it malfunctions then... I'll check that switch when I have time and sun to play with the hard top off. Hopefully I can figure out exactly where it lives!
I'll update this over the three day weekend when the weather promises to be nice so I can leave the hard top off and look more closely at the switches and adjustment. Hope this can help others at some point! And thanks again for the info BobTerry99.
When I replaced the hydraulic cylinders above the windshield at the start of all this, that switch was not working at all - the metal part that pushes down on the switch when it's not locked was bent too far down, so the switch would never indicate that it was locked. I 'bent it straight' at the time and it seemed to work, but it seems the hard top and soft top front locking pins are slightly different (wear, I suppose). The adjustment I had made caused S84/2 to operate properly maybe 40% of the time with the hard top, but not at all with the soft top. So when I tried to put up the soft top, it got to the part where it checks for both front lock switches being in 'lock', saw only one like that, and aborted the rear-bow-down operation. I carefully checked how much lock movement was required for S84/1 to change state, and straightened out the switch actuator paddle on S84/2 to match. When I went to start taking all the switch measurements again at different points in the soft top and hard top cycles, it was all magically working!
Also, I notice that the magnetic switch in the front middle and the magnetic switch on the left rear soft top frame both read about 33 ohms when closed (the wires to both read 0 ohms with the switch replaced with a jumper wire, so it's definitely in the switches). Maybe that's just characteristic of the reed switches.
So hopefully, there will be no further problems or required updates. One takeaway from this is that the limit switches can be adjusted so that one top works and the other doesn't. Another takeaway is that a spreadsheet with all the switches and their purpose, printed out with spaces to write down the state, saved me quite a bit of time today and helped keep everything organized for troubleshooting.
Oh, here's a Top Tip - when you take off the connector X2, take a permanent marker and darken around pins 10, 20, 30, and 40. I makes taking measurements WAY easier and more accurate!
