SL-Class (R129) 1990-2002: SL 280, SL 300, SL 320, SL 500, SL 600, SL 60 AMG
SL/R129: 1994 Sl500 dash cluster
Old Jun 22, 2017 | 01:05 AM
SLman61's Avatar
Sl500
Can parts be swapped from one dash cluster to another? Circuit board,tack fuel gauge ect.
And if so does milage go with circuit board ?
Old Jun 29, 2017 | 12:01 PM
Roger65's Avatar
2001 SL500
I believe the answer is yes to all of your questions.
Old Jun 29, 2017 | 06:15 PM
SLman61's Avatar
Sl500
Dash cluster
Yes I did swaps and found a circuit trace on back of board repairs it with solder and now I have dash lights.So I'm good.
Old Jun 29, 2017 | 06:22 PM
SLman61's Avatar
Sl500
1994 sl500 a/c
Now I'm having problems with A/C my system has charge bit when I set temp to 65 and its around 90 degrees out it doesn't kick in is there a way to test it or bypass the switch to see if it works
Old Jun 30, 2017 | 12:43 PM
SLman61's Avatar
Sl500
Dassh lights
Well I had dash lights on for about an hour then blew circuit again.any ideas what could cause this?
Old Jul 3, 2017 | 10:05 AM
bobterry99's Avatar
'09 S600, (2) R129 300SLs, '03 SL500, '03 SL55
Originally Posted by SLman61
...is there a way to test it or bypass the switch to see if it works
At the dryer there are two pressure switches. I would check to see if the low-pressure switch (black) is closed. Also, I think you should consider starting a new thread if you seek further assistance.
"Blew circuit" -- the traces on the cluster circuit board are burned? If so, then I would suppose there is an external wiring or component issue that is drawing too much current from the cluster's lighting circuit.
Old Jul 4, 2017 | 12:10 AM
SLman61's Avatar
Sl500
Circuit tracers dash cluster
Thanks for info.I switched the circuit boards out with another on used dashlifhts work fine on that one and don't blow out.I would keep it installed but the speedo and registers one hundred mph when going 30 lol so either I have no dash lights or fast speedo..I switched speedos and still the same so I will stick with the no dash lights for now till figure it out
Old Jul 4, 2017 | 12:13 AM
SLman61's Avatar
Sl500
A/C
Thanks bobterry99 for that info..I will start new thread.I'll check those high low switches.
