SL-Class (R129) 1990-2002: SL 280, SL 300, SL 320, SL 500, SL 600, SL 60 AMG
SL/R129: 1994 sl500 A/C not working
Old Jul 4, 2017 | 12:19 AM
SLman61's Avatar
Sl500
My A/C is not working I turn it to low temp and hit blue button on center vents and clutch doesn't come on.Fan does work fine I checked at Schrader valve and freon does come out and I checked cluth on compressor it turns so I was told to check high low switches at dryer.is there a fuse just for the A/c clutch ?
Old Jul 4, 2017 | 12:00 PM
Lee Wireless's Avatar
1995 SL500 - 2017 AMG GLC 43
See attachment
File Type: pdf
Old Jul 4, 2017 | 09:08 PM
SLman61's Avatar
Sl500
A/C
Thanks for info
Old Jul 14, 2017 | 03:48 PM
SLman61's Avatar
Sl500
1994 sl500 charging system
None of the fuses under the hood are blown..I checked voltage at battery when car running its at 11 V so alternator not charging.I see you can. Replace regulator in alternator is it poss this could be problem? I guess I need to check voltage to alt if it is present the it must be regulator ???
