SL/R129: Instrument panel lights out
Anyway I noticed the lights are out for the fuel gage and whatever gage sits to the right of it. (smile) There is also no light on the temperature display (not sure there is one, but would expect so.)The radio and right side of instrument panel seem fine.
I'd like to do as much of the easy maintenance as I can without paying the dealer an arm and a leg for small time stuff.
What should I check..fuse? bulbs? where are they?
Will post a photo this weekend.
Cheryl (golfin'lady)
Also ... may be related? ... my temperature display numbers and text get ditorted orf and on. Pressing or tapping the moulding around the edge of the unitseems to fix that. I don't know if your unit is doing that.
A while ago when I posted these simptoms, a guy wrote back to say that regarding the distorted numbers hid MB dealership "fixed it for a grand total of $ 32.25 by changing a bulb (oo2-544-02-94 light bulb). I was skeptical of the fix but it has been 4 months without it happening again".
It is funney how we get used to things. I have not taken the time to implement a $ 32.25 fix. Maybe I'll remember it when the annual maintenance visit comes due.
ThanksCher
Sounds like this is all loose, failed bulbs. If you are having one or two replaced, replace them all because the older ones will be dimmer than the newer ones.
It is easy to pop out the cluster with the 2 Mercedes tools.Everything works fine now.
Also recently half the instrument display will sometimes get dim but is still readable. Hope this is coverered by MBs extended warrantee as $300 seems excessive to replace a bulb.
