SL-Class (R129) 1990-2002: SL 280, SL 300, SL 320, SL 500, SL 600, SL 60 AMG
SL/R129: 95 SL320 scraping noise Left rear wheel
Old Aug 24, 2017 | 01:56 PM
Rtcmd's Avatar
1995 sl320 and 2011 ml350
Would anyone knows where this noise is coming from...been hearing this scraping noise in the left rear wheel when driving. The noise goes off and on while the car is running. The noise is much noticeable after being parked overnight or longer. It diminishes a little bit after driving for awhile. Sometimes it goes away as you keep driving the car. It seems like the more you drive the car on a daily basis the noise would be less noticeable or even goes away. I'm thinking of something with the emergency parking brake that causing the noise. Does anyone have experienced this kind of problem? What seem to be the cause of this noise? Please help. Thanks.
Old Mar 10, 2020 | 03:31 AM
RaiderG's Avatar
2014 GLK250
Hi, i am facing with a pretty similar issue, did you find out why ?
Old Mar 11, 2020 | 09:30 AM
FATHERTIME's Avatar
94 SL320 98 SL500 99 SL600 07 SL55
Pull off the caliper and rotor I suspect a broken spring. Do you have longer wheel bolts than factory? if long enough they can hit parking brake parts.
Old Mar 13, 2020 | 06:25 AM
Rtcmd's Avatar
Raider,
the back plate was bent and it's making noise when it makes contact with the rotor. Straightened it out and it's okay now.
Old Aug 9, 2020 | 01:55 PM
NCMountie's Avatar
2021 GLS450, Lunar Blue Metallic
I had a similar sound/issue, but it was the right-rear wheel speed sensor.
