SL/R129: 129 Radiator Grille
It turns out that the individual slats are available separately so if, as in my case, you have just one or two which have been damaged, it is much less costly to replace just the ones you need.
I replaced the top-most one, part no 129 888 0038, cost about $70.
I will defintely get around to putting an old motorbike tyre between the bike and the car to avoid doing the same to the latest SL.
As regards the bars, it's not quite the ideal solution I envisaged - there colour match is not bad but not perfect, I assume there's some change over time (8 years in my case). Also, all the bars except the top one are rivetted in place so not the easiest to replace.
Ken Silver
~1993 SL500, glistening triple black, xenons: http://www.kensilver.com/SL
~1999 SLK 230 Kompressor, silver/black leather, CD, immaculate (my wife's)
Thanks!
Ken Silver
I brought it to their attention and they replaced it at no charge, no questions.
They stated that it was either wax or the protein based solvent used to detail it.
C.
