SL/R129: 1997 SL600 Headlights wont turn off
Hi All- New to the Forum, First post. Last night i pulled into the driveway parked and went inside... later noticed my headlights were still on. I checked the switch to see if i had not turned the off (usually let them run auto) but the switch was in the off position. i ended up disconnecting the battery so i didnt kill the battery. this morning going over it again and the lights still remain on when batery was reconnected. i just noticed the windows are acting up ( not rolling down automatically 1/4" or 6mm when door is opened and rolling back up to allow for re-seal once door in in closed position) Any Ideas what could be failing?
Russ
Russ
![](https://mbworld.org/forums/images/ranks/veteran_army.png)
The lights are typically a bad switch---the doors although you may think they are sympathetic to the high beams, they are not--separate issue as you lost all memory when you disconnected the battery-----the windows seats sunroof bla bla have to be relearned
Thanks Plutoe- I'll have to look into a new light switch. How would I relearn the windows? I've had the battery disconnected before and have not run into this issue.
