SL/R129: Interior lights
The bulbs are fine as when they are manually switched on, they work but the doors will not trigger the lights on/off when on the setting to do so.
Is there a fuse or something located in the plastic area around the interior lights as I cannot find a fuse for this function.
This happened after i stupidly installed new bulbs without first switching the lights off- got a spark and some smoke...
( I was replacing older yellowish smd led panel with white smd leds to match the rest of my car- i put the old yellow panels back in until i find a solution...)
I'd like to know if my problem is the same as the one above, and where I can find the n2/4 control module- is it in the separate box above the fuse box under the hood?
Thanks in advance for help/guidance
Dan
