SL/R129: Roll bar - top stuck?
I removed my center console, briefly disconnected my switches, now the roll bar is stuck in the up position and the top won't operate. I held the roll bar switch in the up position for 15 seconds to reset it, heard the clicking but no luck.
The window operation as part of the top was working in reverse briefly, I synced the windows and now the top switch does nothing.
How can I fix this?
The wiring of the switches may have been damaged in the removal-replacement process. Depending on the wiring harness connections and the surrounding cover over the wire an exposed section might be "shorting" the proper signals.
I would stat with retracing those issues. The top controller could have been confused and testing for codes would be a start.
Look to Klaus of Top Hydraulics and Bobterry99 for excellent answers
