1995 OEM Radiator?
What company supplied the radiators installed on new SL 320s back in 1995?
Was it Mercedes-Benz or some other manufacturer? Thank you very much. |
MB/OEM 95 "R129 Sl320" Radiator comes as "Behr",,
also, "Nissens" is good brand..:) -;ZAYED;- https://cimg2.ibsrv.net/gimg/www.mbw...8bf5ddeda7.jpg |
Originally Posted by cm60k
(Post 7506672)
Why need new Radiator..?, any leaks in there..?,
-;ZAYED; |
(Post 7506730)
-;ZAYED; It may not be performing as efficiently due to corrosion as a new one would. |
No need to tossing any $$$, if your Radiator is okay,,
for best cooling results:- put new anti-freeze coolant with new thermostat, and check the Radiator hoses, if they not gets any crack..:) -;ZAYED;- |
(Post 7506748)
for best cooling results:- put new anti-freeze coolant with new thermostat, and check the Radiator hoses, if they not gets any crack..:) -;ZAYED;- Still, your suggestion is a good starting point. What I am seeing is that the temperature gauge rises to about 80 - 82 degrees Celsius, maintains that temperature for a while, then starts building up temperature again. That is why I suspect corrosion in the radiator and/or problems with the fans. |
Yeah, you're Right,,
you may have a bad corrosion that clogged the water tunnel, or bad Thermostat spring..!,, prefer to change them immediately..:) -;ZAYED;- |
I have concerns for the aging radiator in many benz vehicles. I feel the joints and connecting pipes will breakdown, much like the older plastic parts of any older cars
Behr was the source I have used. good product but USA Moline had products that helped 20 years ago, not even sure they are in business |
Originally Posted by SRHsl600
(Post 7508634)
