SL-Class (R129) 1990-2002: SL 280, SL 300, SL 320, SL 500, SL 600, SL 60 AMG
SL/R129: 1997 320 SL Fuel Injectors Not Firing
Old 10-16-2018, 09:03 PM
jimbozambo's Avatar
1997 320 SL
US 1997 320 SL
After replacing bad fuel pump with filter and installing a new battery the engine cranks but wont fire. I have normal pressure at fuel rail. Engine runs on starting fluid spray to air intake. Only code is Cam Position Sensor; sensor replaced twice, wiring from sensor to computer tested good.
Additional Data:
Every fuse under hood and in trunk tested ok
All computer connections look fine and have been reseated.
Crank Shaft position sensor tested ok
Locking and Alarm systems work ok and I have done the steering wheel up/down dance.
I am a long time lurker but first time poster as i am at wits end.
I am NOT a mechanic. I got this far reading forums and have a neighbor who does racing engines help me.
Thank you for reading and helping!
Old 10-17-2018, 12:49 PM
bobterry99's Avatar
'09 S600, (2) R129 300SLs, '03 SL500, '03 SL55
I'll guess you may have overlooked the fuses installed atop the Base Module. The Base Module is located among the other electronic modules beneath a plastic cover in the right-rear engine compartment.
Old 10-17-2018, 01:31 PM
jimbozambo's Avatar
1997 320 SL
Thanks bobterry. I think the base module you referenced is what I’m calling the computer (under hood under passenger side window). All the fuses in that compartment are fine.
Jim
Old 10-03-2023, 05:04 PM
Dieselwigs's Avatar
SL320
Hello Jim,
I appreciate your post is several years old, but I am experiencing a similar issue an wondered what was the eventual solution to your non-fuelling problem?
Chris
Quick Reply: SL/R129: 1997 320 SL Fuel Injectors Not Firing
