SL/R129: 1996 r129 roll bar fault lamp
Roof warning lamp and roll bar warning lamp came on, neither would work.
My dealer reset the roof warning lamp and the soft top now works perfectly.
Dealer could not reset or find a fault with the roll bar .
So, roll bar works , I can raise or lower the roll bar using the switch.
But I have roll bar warning lamp continuously lit on dashboard and I have flashing warning lamp on roll bar operating switch only when the roll bar is in the down position.
Any help appreciated.
thanks
Pat
I would find an independent shop which has Mercedes "Star Diagnosis" to read the code. Or better yet, I would invest c. $300 in the purchase from aliexpress.com of a Chinese-cloned Star Diagnosis of my own.
There are four stores fault codes but Dealer did not diagnose a specific problem.
The comedy’s are as follows
134. Control unit N52 (Soft top control module) is defective
135. Has exactly the same text
99. <no error text found>
99. Has exactly the same text
The soft top and roll bar are both working perfectly, but I still have the roll bar warning lamp on the dash up all the time and a fault on the roll bar switch when it is in the down position.
anybthoughts greatly appreciated
