SL/R129: 99 SL500 NEED RADIO HELP
1998 SL600 Sport/Pano, 1999 SL500 Base, 2004 Jaguar XJR, 95 Impala SS, 2010 Crown Vic Police
99 SL500 CD CHANGER PLUG RECEPTACLES
Original CD changer from 99 SL500
Optical cable receptacle left, power and control right - 3 pin.
Plugs angle in at the bottom of the changer.
This is the original CD changer from my 99 SL500. I replaced it with an identical unit used off ebay. The Audio 10 CD radio works perfectly with this unit. If your car is pre-99, you should only need the D2B optical cables available on ebay. And the Audio 10......
Sorry I can't seem to get these pictures small enough. I'll keep trying.
Looks like this is going to be a bit more difficult (kind of like the BAS guys said it would be).
The wired (not fiber cabled) CD changer has a 10 position connector with 9 pins used. 3 for power, ground and control; while 4 are most likely stereo audio signal pairs. That leaves 2 wires unaccounted for. Initially I thought they might be a audio feed to the sub-woofer, but the sub must get it's audio feed from the head unit itself. Nothing hard is ever easy.
Mahunt, 2Jags. I have a SL500 (1999) with CM2299 and Telephone, CD Changer (with fiber optic link). I want to change the CM 2299 by the 2910. I understand from your experience it is possible. Could you pls confirm the CD changer still work. I understand from 2Jags that a technician had to programme the radio, do you have the procedure? Is there and error code in the diag tooling SW to clear. what happen to the telephone? The backlight at night is orange in my car. Is it the case for the 2910 radio? Thanks for your support.
AUDIO 10 CD
Hope this helps.
Does your telephone work? I just read something the other day about the SOS system on 2000-2002 cars no longer working because it is analog and Mercedes went digital in 2008. I would think that affects the phone.
#33
Then it will be an easy plug and play swap. You'll have your CD changer and an in-dash changer.
