SL/R129: P0445 EVAP Emmissions Leak
R129 SL55 AMG & W208 CLK55 AMG
So the saga continues,
I've replaced:
1. EGR Valve
2. Fuel cap
3. Air Mass ( For the F**k of it, don't ask why )
Bosch service centre tells me it could be the fuel guage and pressure sensor ( obsolete )
They also said the vaccuum hose needs to be replaced which they haven't ( I have no idea why )
Anyways, anyone know the part number or wher I can source the fuel presure sensor?
1999 SL500
Thanks in advance.
I've replaced:
1. EGR Valve
2. Fuel cap
1999 SL500
Thanks in advance.
The EGR valve has nothing to do with the EVAP system, so that part change is as much a puzzle as the air mass sensor replacement.
If I were going to continue playing Parts Roulette in lieu of actual diagnostic work -- something I personally would not do -- I would focus on the vacuum line attachment points and ignore the fuel tank pressure sensor. Note that the sensor is not a fuel pressure sensor, since it measures vacuum within the fuel tank.
You might go to the "Tech Help" forum at peachparts.com and do a search. Years ago that forum had no fewer than four professional Mercedes techs participating on a regular basis. I expect you will find EVAP system leaks have been discussed many times and may get a better idea where to place your next Parts Roulette bet.
Ahmed (08-18-2019)
Just wondering if you ever got this sorted out and how? I have a 98 same issues. Replaced cap, purge valve, gas tank sending unit, ran smoke test and replaced hose under front fender, still get CEL and 0445 code.
94 SL320 98 SL500 99 SL600 07 SL55
I had that on my 94 SL320 and it turned out to be charcoal canister letting bits get stuck in purge valve I cleaned it out and tested that it did seal I put an inline fuel filter in the hose coming from the canister never got code again
cecil510 (12-12-2021)
