SL-Class (R129) 1990-2002: SL 280, SL 300, SL 320, SL 500, SL 600, SL 60 AMG
SL/R129: How to reset/flash the ECU settings?
Old Oct 3, 2019 | 01:42 PM
1littlecastle's Avatar
1995 M-B SL320
Does anyone know the sequence to manually resetting the ECU using the ignition and throttle pedal method on a 1995 SL320?
Old Oct 4, 2019 | 11:18 AM
bobterry99's Avatar
'09 S600, (2) R129 300SLs, '03 SL500, '03 SL55
There is a way to reset the shift adaptations for an electronically-controlled transmission using the pedal, but apart from the 4th/5th gear control your transmission is hydraulically controlled.
