SL/R129: SL500 V12 swap
1995 sl500
SL500 V12 swap
Hey guys. So i am officially starting to swap a v12 into my 1994 sl500. I bought a whole 1994 sl600 car so i have everything i need. I will be updating pictures and i will be posting a couple of questions. To start off i have an electrical question.
1) i have my speed sensor wire (at least thats what i believe it is) here is a picture, please correct if im wrong. Im holding it with my hand. There is a connection going off of it and there is the other connection in frame. This connection goes to the ecu box, does the speed sensor connect to that? I will clarify its location better below with more pictures
These 2 wires (not the speed sensor held by my hand, but the other one in the first photo and the one down below) both connect to the same main wire that goes into the ecu box. The connector pictured below appears to connect to the solenoid that is also picture (based on how it is bent, could be wrong) This is the front of the ecu box, right before the passenger strut.
Can anyone confirm this?
Thanks!
Thanks!
