SL/R129: Hardtop latch issue
At any rate, I would adjust the position of the latch. To do that remove the hard top, have the soft top out of its storage compartment to expose the latch, loosen the three nuts which secure the latch to the body, move the latch upward, and re-tighten the nuts.
I put the hard top on today, it clicks down in the rear but pops back up. So it is latched but has a gap it was one side now both. I had all the cylinders replaced a few months back. Any ideas?
Your rear latch mechanisms were installed too low when they were replaced.
If you look to where the 3 bolts were ORIGINALLY located (look for original scuffs in the black paint) you might be able to locate the right position without too many adjustment trials.
