SL-Class (R129) 1990-2002: SL 280, SL 300, SL 320, SL 500, SL 600, SL 60 AMG
SL/R129: M113k swap
Old Jan 27, 2020 | 09:16 PM
Nekola90's Avatar
1999 500sl
M113k swap
Hello all, has anyone done and shared info about an m113k swap from an SL55, e55, etc into the r129? I have a 99 500sl and it has the standard m113. I figure the bolt in process should be easy enough especially given that the transmissions are the same 722.6. The problem would be the wiring harness and ecu and getting all the electrical stuff figured out. I've seen some mention of CLs swapped to the m113k but never an SL. Any info would be greatly appreciated.
Old Jan 28, 2020 | 08:31 AM
mahunt's Avatar
1997 MB SL600
A few folks have just do a search on Google.
Old Jan 28, 2020 | 08:51 AM
Nekola90's Avatar
1999 500sl
Yes Google is where I've started...
Old Jan 28, 2020 | 09:18 AM
mahunt's Avatar
1997 MB SL600
You didn't like what you found over at BenzWorld?
Old Jan 28, 2020 | 11:35 AM
FATHERTIME's Avatar
94 SL320 98 SL500 99 SL600 07 SL55
Here is a good posting on this as I'm going to do the same .
https://mbworld.org/forums/sl-class-...-ecu-tune.html
Old Jan 28, 2020 | 11:50 AM
Nekola90's Avatar
1999 500sl
I saw that one, he swapped an NA amg engine, not the supercharged one, it helps a little, but not a lot as it was basically plug and play
Old Jan 29, 2020 | 01:55 AM
Ahmed's Avatar
R129 SL55 AMG & W208 CLK55 AMG
Swapping out a Naturally Aspirated M113 for a force induced one is not plug and play for sure.
You may want to change out your complete intake manifolds along with the furl rails, and one thing you are definitely going to face is.... ta taaaaa WIRING HARNESS issues.
You will also need to swap out your ECU for this and virginize it too.
Then comes your transmission and rear diffs. That's a whole other story.
Old Jan 29, 2020 | 02:30 AM
FATHERTIME's Avatar
How's your swap project doing last I saw you were looking for an ECU tune. Did you do that or is it running fine as is?
Old Jan 29, 2020 | 02:39 AM
FATHERTIME's Avatar
This may be an option if you get a 5.5 M113 in the car.
https://www.weistec.com/m113k-supercharger-system.html
Old Jan 29, 2020 | 04:09 AM
Ahmed's Avatar
The car is running fine, that's why I haven't even bothered with the tune yet.
Also, the tuner is asking $1500 for this, it's time consuming as he will be performing the dyno runs, parameter checks and adaptations and working along side Jerry from Eurocharged to get the tune just perfect.. not only to simulate the 55 AMG tune, but actually a nice power bump up to to 385hp too.
I'm saving up as we speak. School fees are killing me!
Old Jan 29, 2020 | 08:56 AM
FATHERTIME's Avatar
Have you had it on a dyno to see what it puts out now after the swap?
Old Jul 9, 2024 | 10:34 AM
Vinza3's Avatar
1995 Mercedes SL320
hello, did you ever do this project?
