SL/R129: Turn signal started to come on and stay lit after the car is parked
I noticed this after about 30 minutes that the right side turn signal lamp front and rear was lit
I took the car for a short test drive and used both the left, right turn signal and warning signal as well and all worked as it was supposed to do.
So i parked the car again and went back in to my house
After a while a looked out the window and sure the right side turn signal front and rear was lit again.
Back out again and started the car and the turn signal went out again.
Opened the hood and checked the fuses and could not see anything wrong but after this the right side turn signal stopped flashing and would just stay lit when ii put the turn signal lever to the right.
So i just took out the fuse for the turn signal and i will check it tomorrow.
Any of my fellow member here on the forum have any idea what cause this?
Is the turn signal relay starting to go bad? If so where is the relay located?
I bought a Blazer ZR2 where the switches for the mirror adjustment, the switch for the 2WD - 4WD - 4WD Hi - 4WD Low - Auto 4 WD and the remote key fob did not work and i just took them apart and cleaned them using electro clean on q tips and they all started to work like i had replaced them with brand new switches
I know that a lot of people replaces the battery in their key fobs even if they replaced the batteries a week ago thinking that the batteries are the problem when the problem often it is a dirty key fob. Just open it and clean the contact points on the solder card on the key fob
But i have already fixed the problem on my SL
(or it works as it is supposed to at the moment)
What i did was to have a look at the fuses and they did not look like new to say it like this so i took my Dremel with a little brass wire brush on and cleaned some of the contacts in the fuse box (top and bottom of the fuse contact points) and also cleaned the fuses and everything works like a dream
Just to be on the safe side i replaced 43 of the fuses even if i had cleaned them
The fuses have aluminum "strips" on them which often gets very dirty/corroded.
I have looked for copper fuses up here in northern Europe but no copper fuses to get hold of up here
Since i think copper fuses are much better than the aluminum ones, i must have to order them from the US since the US is the only place i have seen the copper fuses for sale
