SL-Class (R129) 1990-2002: SL 280, SL 300, SL 320, SL 500, SL 600, SL 60 AMG
SL/R129: R129 300SL Backlight of cluster, A/C, buttons are vents are not working
Old Apr 29, 2020 | 04:10 PM
Julio Noria's Avatar
1990 R129 300SL, M103, 5-speed manual transmission
Hello guys. I have a 1990 Mercedes 300SL (M103, 5-speed manual transmission) with the following:
Issue:
Backlight illumination of Instrument cluster, A/C control, seat controls and center console buttons is not working. All check lights and indicators are working normally.
Tests:
* Moving dimmer shaft from end to end, nothing happens.
* Tested voltage on pin 8 of connector 1 on the harness and 12V is present when I turn the lights on in the lights switch (1st pass).
* Light of console ashtray is turning on when I turn on the lights.
* Doors and foot rest lights are also working normally when the doors is opened.
* Bulbs are Ok and tested.
* Rheostat seems to be Ok, measure between pins and turning knob from one end to another goes from 0 ohms to 47K ohms (or something like that) in both directions.
* Temperature LCD display seems to get dimmed or without backlight when the lights are turned on.
* Cluster harness seems to be in good shape, no cracks, no short circuits.
* PCB connector's pins were resoldered.
* Rheostat pins were also resoldered.
* A couple of tracks (small sections) which are far from rheostat zone seems overheated but I tested continuity from several ends which runs over those tracks an the current flows.
What other tests can be performed? I have another cluster (which has several issues) and it behaves the same way.
Your help will be highly appreciated!
Thanks in advance.
Julio
Old May 1, 2020 | 07:27 AM
bobterry99's Avatar
'09 S600, (2) R129 300SLs, '03 SL500, '03 SL55
I had the same issue with a 1990 300SL with 5-speed manual transmission. A friend who is an electronics whiz looked at the circuit board, immediately recognized an integrated circuit dedicated to lighting control, and touched-up its solder connections. That's all it took to get the lighting working again.
Old May 4, 2020 | 05:10 AM
Ahmed's Avatar
R129 SL55 AMG & W208 CLK55 AMG
I have these issues as well...
Thank you once again Bob.
