SL/R129: Just Got a 96 SL500 need some help please!
There are lots of little things that need to be done, and I'm hoping you all can help. I've been lurking for the past few days but figured I'd make this and just ask for help regarding a few issues
- I have a car interior listed as "parchment" and am looking for interior trim pieces, mainly,
- those stupid sun visor mounts
- the trim that covers the rear defroster (that you unplug to take off the hard top)
- rear fuse cover
Does this mean its an entirely different color from the Beige and tan colors? I haven't found anything listing the pieces as parchment
- I just replaced the incredibly old headlight bulbs with Xenons (i had to take the entire driver assembly off, drill a screw into the back of the old bulb and yank it out lol)
but the lights are still incredibly dim and very focused, like I have two flashlights strapped to the hood of my car. Anyone know of this issue, what I can do? Is it possible that the bulb housing in the actual assembly is clouded or dirty? If so can I fix it or does it need to be replaced? Also the left parking light is out, is it a pretty easy fix? I'm planning on getting a bulb and trying today/tomorrow.
- The stereo is driving me nuts
- The antenna motor works but wont catch the antenna track, and every time I turn the car on or off I hear it struggling to try to do its job, but nothing happens.
- Does anyone have the mounting depth of the speakers, or of the speaker assembly for the doors, I want to replace the headunit and speakers but don't want to have to make new mounts for the speakers.
- Does anyone have any experience with lowering their car height? what did it do to the suspension? I'm not going to bag the car, so it'd be coilovers, but I dont want to sacrifice the "luxury roadster" ride comfort, though I would like steering to be tighter and for the car to sit about an inch lower.
Thanks everyone!
Headlights have always been no-good and there are several good upgrades available. Research the issue.
Lowering springs are easy as long as you do not have the 'ADS' hydro-pneumatic computer controlled hydraulic suspension called ADS (which DOES provide fantastic ride and handling quality)
thanks
You should expect hydraulic cylinders in the convertible top mechanism to start leaking any day now. They 'age-out.' and after-market rebuild of yours off-site is the way to go. If you do the work, cylinder rebuild is roughly $1000. A Dealer job of $15,000 would be about right.
As far as steering play. I am not familiar with that as an issue. Look for a loose steering coupling or worn tie rods or ball joints. Sometimes a loose wheel bearing, Some tires are prone to 'railroad tracking.' Tires and alignment are often the cure. . Not enough CASTER (which causes self centering) will cause 'twitchiness'
IF you had ADS you would know because of the dash 'RIDE CONTROL switch.
Few more question for anyone thats done any audio swap, what is the mounting depth of the Bose woofers and mids? I really like a 3-way component but critchfield says it wont fit and frankly I dont wanna rip my door off to figure it out.
Also does anyone know the part number or name of the trim piece that covers the cable that needs to be disconnected to remove the hardtop, or the pn/ name of the rear fuse box cover?
