SL-Class (R129) 1990-2002: SL 280, SL 300, SL 320, SL 500, SL 600, SL 60 AMG
SL/R129: r129 soft top button
Old Mar 14, 2021 | 09:10 PM
davidwball's Avatar
1998 Mercedes SL500 245,000 miles
Question r129 soft top button
I have been driving myself crazy trying to figure out why when I put my top down everything is normal with the car but when I have the top in the up position the button for the top(which is just above and to the right of the shifter) will be a solid red but when the car is in drive the red light starts to blink. Please tell me what I have been overlooking. 1998 sl500 thank you all for your time
Old Mar 15, 2021 | 12:22 AM
sushipaste's Avatar
1999 SL600
soft top not latched properly. Try adjusting the latches in the rear of the inside of the tonneau cover
Old Mar 15, 2021 | 05:47 AM
Pazo's Avatar
R129.067 (500SL '93), EQE, MGB
Sushipaste is right. Take your manual soft top tool (or similar, see instructions in owner's manual) and lock all the latches. Changes are that one of the locks fails to latch properly. A more professional approach would be to read the RST diagnostic trouble codes (DTC).
Old Mar 15, 2021 | 11:08 PM
davidwball's Avatar
thank you for the help i will give it a try
Old Mar 15, 2021 | 11:10 PM
davidwball's Avatar
thank you for the info i will try getting the RST codes. i have never done this before is there a video which i can learn from?
i will let you know if i figure this out.
Old Mar 16, 2021 | 01:13 PM
sushipaste's Avatar
1999 SL600
Get a ratchet, extension, and 10mm socket. Undo the bolts holding the latches in the rear inside of the tonneau cover, then they can be adjusted up and down
Old Mar 17, 2021 | 11:45 AM
davidwball's Avatar
sl500 top issue
I adjusted the latches but still having same issue
now when i put the top up my roll bar will not raise, it only moves about 2 inches then back down. this will happen 5-6 times then stop not completing the raising of the top cycle.
thank you for help
Old Mar 17, 2021 | 04:04 PM
sushipaste's Avatar
1999 SL600
thank you for help
next step: find an indy with star diagnostic
Old Mar 17, 2021 | 07:16 PM
davidwball's Avatar
i will do that thank you for your help
Old Mar 18, 2021 | 09:15 AM
Sandy Eggo's Avatar
'00 SL600
Theory: at some point in the past, someone replaced the top hydraulics and the microswitch on 1 or both of the bow extension cylinders got out of adjustment.
Please watch this video and pay particular attention beginning around 4m40s
The only problem with this theory is that if it were the cause, then I believe the top wouldn't open or close at all. But it might be worth an inspection just to make sure.
Old Mar 18, 2021 | 04:23 PM
davidwball's Avatar
thank you i will try this since that cylinder was replaced a short while ago. i did discover that the micro switch 129-821-16-51 located on the passenger side for the tonneau cover lock remains in a closed condition regardless of activation. I checked the continuity of that switch by manually moving the micro switch and it showed no change in continuity in either position. Is this normal or is that switch faulty?
Old Mar 18, 2021 | 05:52 PM
Sandy Eggo's Avatar
'00 SL600
I'm not smart enough to know for sure but just thinking about it logically, I'd say it is not normal. Otherwise, what would the point of the switch be?
I hope it's helpful and not just sending you down a rabbit hole. Good luck!
Old Mar 19, 2021 | 12:59 AM
sushipaste's Avatar
1999 SL600
Hold up, did you adjust the lacthes up or down? Are they of even height? check with the hardtop on and check the gaps. The gap between hardtop and the quarter panels should be about 1/4 of an inch
