SL-Class (R129) 1990-2002: SL 280, SL 300, SL 320, SL 500, SL 600, SL 60 AMG
SL/R129: Whine from rear can’t find fix
Old May 1, 2021 | 04:38 PM
slradster's Avatar
2000 Mercedes SL 500
I was looking for an answer on the forum but I have a 2000 SL 500, and there is a loud whine that is constant when the car is running. The sound is loudest in the rear, and I’m not sure what it could be, since my SL isn’t equipped with air suspension or anything like that. I attached a short vid with the noise.
note: we recently replaced the fuel pump (was not an oem part)
Old May 2, 2021 | 01:10 PM
FATHERTIME's Avatar
94 SL320 98 SL500 99 SL600 07 SL55
Get a mechanics stethoscope at Harbor Freight and crawl under right rear of car and listen to the pump
Old May 2, 2021 | 07:59 PM
sushipaste's Avatar
1999 SL600
If the noise started after you put a non OE fuel pump on the car, then the problem is obvious...
Which brand did you use, lol.. Should've only used Pierburg
Old May 3, 2021 | 07:11 PM
Kebowers47's Avatar
001 s600, 94 sl600
It sounds like the fuel pump.
