SL/R129: 500SL thats feels like a 300
While driving the car, there is quite a noticeable differente before and after ~3500 rpm. I can actually feel the car pull much much stronger after 3500. In any other situation the engine is smooth as silk, and very responsive.
The car has 25.000 km and just did a major service with:
- All engine and trans oil and filters
- Spark plugs
- Rotors and Caps
- Fuel filter
- Air filter
- Crank Position Sensor (car once died while running for 30 min in Park)
After a little bit of searching on foruns I went and looked at the MAS Relay and this is what I found:
Is this red wire supposed to be here? It connects from the OVP to the MAS relay with a 15amp fuse. Also, the MAS Relay it's not from a M119, looks like from a M104 engine.
Any idea about what's all this?
Thank you so much for all the info. Amazing to see how such a small piece can make a car drive complety different!
Now I'm gonna drive the heck out of it this summer!
