SL-Class (R129) 1990-2002: SL 280, SL 300, SL 320, SL 500, SL 600, SL 60 AMG
SL/R129: Interior light issue
Old Sep 12, 2021 | 07:07 PM
jimbo409's Avatar
2004 sl
Just bought my 91 sl and the interior lights don’t come on when I open the drivers door,I tried pushing in the door jam switch but nothing happens
when I open the passenger door both door lights and interior lights come on. Just nothing with the drivers door. Any ideas what to check
Old Sep 12, 2021 | 10:27 PM
mahunt's Avatar
1997 MB SL600
Yes.
Pull and inspect the driver's side switch to make sure it works.
Old Sep 13, 2021 | 07:29 AM
JDWilson's Avatar
1990 500SL
I have the identical problem on my 1990 SL. I've checked the door switch and it is working correctly. I've had two independent shops look at it but neither one has a clue re. how to repair it.
Maybe someone will see this thread that knows where the problem lies.
Old Sep 16, 2021 | 12:29 AM
sushipaste's Avatar
1999 SL600
replace the left dome light switch
Old Sep 16, 2021 | 06:14 AM
JDWilson's Avatar
1990 500SL
The left dome light switch works as it should when you push the buttons to turn it on/off. The problem that the OP and I are both having is that when you open the left door (without opening the passenger door, none of the lights come one. If you open the passenger door, the correct lights come on and if you walk over and open the driver's door, those lights come on exactly as they should. If you leave the driver's door open while the passenger door is open and then close the passenger door, the driver's side lights immediately turn off.
Old Sep 17, 2021 | 10:52 AM
Kebowers47's Avatar
001 s600, 94 sl600
You are experiencing a poor/bad connection from the LF SAM module. power is not getting from the door switch to the SAM to the door.
Old Sep 17, 2021 | 11:43 AM
JDWilson's Avatar
1990 500SL
1,What does SAM stand for?
2. Please tell us where the LF SAM module is located.
3. Since the lights will turn on in driver's door if the passenger door is opened, are there two wires on each door that go to this module?
Thank you for your help.
